Posted by pete 23 on June 20, 2012 at 19:50:39 from (74.32.238.2):
In Reply to: 656 hydro exploratory posted by ChShaffer on June 20, 2012 at 19:21:35:
Question, is the main suction tube loose (38 in parts illustration)or is it the pipe the hose hooks onto that has come loose from the main suction tube. I am trying to remember how pipe fastens to tube as I have it in my head that the hydrostatic tractors used a larger aluminum suction tube than the steel tube used in gear drives which pipe was welded to tube. If main tube is loose you may be in big trouble as I have had to split them to repair on gear drives when bracket broke off where it is bolted on. If main suction tube is tight you might be able to just leave the return hose off entirely as long as main tube is well below oil level. I have seen guys do this when some loads like loaders drop so fast it keeps blowing the hose off or bursting it. The reason for the hose and pipe is because the pumps deliver more gal per min than the capacity of the reservoir so it depends on what you are using if it will get you by or not.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
