Posted by doehmke on June 27, 2012 at 13:07:52 from (67.233.244.36):
If I remove the front and rear bearing cases and connecting rod caps, is it possible to get enough movement of the connecting rods and clearance to remove the crank --- if the pistons are stuck? If this is possible, it seems it would be easier to pound out a single piston at a time, pounding on one with resistance on the other three. Does this make sense?
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
