Posted by gene bender on June 29, 2012 at 16:22:01 from (67.55.226.123):
In Reply to: model A cooling fan posted by Teds farm-all on June 29, 2012 at 13:11:28:
It is worn out because of no oil. I did fix one just for fun and put a piece of leather on the shaft so it would act as a seal on the rear. It did work if you will check your shaft and the hub you will see its worn thats why the oio leaks out the back. The new replacements have bearings and seem to last. You mite have added too much oil. You could also add a piece f leather or something on the outside at the rear of the shaft. It all depends on how much you do use the tractor.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
