Re: Model A cooling fan
Posted by Haas on June 30, 2012 at 06:24:59 from (75.201.196.206):
In Reply to: Model A cooling fan posted by Teds farm-all on June 29, 2012 at 21:04:49:
There is no shaft seal to speak of on the fan hub shaft. Centrifugal force throws the oil to the outside of the hub and keeps the oil from coming out. The grooves you speak of serve as a sort of "pump" to cirulate the oil and lubricate the bearing. If your shaft has little or no play, you don't need a new fan assembly. Just make sure you get it back together properly and put oil in there as others described.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
