Re: Narrow front wobble fix??
Posted by Zachary Hoyt on July 01, 2012 at 04:36:15 from (184.12.71.137):
In Reply to: Narrow front wobble fix?? posted by lbg57 on June 30, 2012 at 18:57:31:
You can get them on ebay for a lot less than $1000, I am not
sure how much but not too bad. No idea on quality. I tightened
up the steering in my H by unbolting the pipe plug cover over
the worm gear bearing and putting a washer in between that
cover and the bearing. What was causing the loose steering on
mine was that the worm gear was moving back and forth in the
housing for 1/8" or so rather than immediately turning the
sector gear as it was intended. I went from 1/3 turn play to
about 1". First washer I tried was too thick and made the
steering stiff so I put in a thinner one and it was just right.
Zach
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
