Re: SMTA governor
Posted by The tractor vet on July 01, 2012 at 08:00:09 from (76.212.225.132):
In Reply to: SMTA governor posted by hayfarmer on July 01, 2012 at 07:53:09:
With out being there to hear and see we are guessing . First make sure that ya have good fuel flow to the carb from the tank. What plugs ya running ?? IF your working the snot out of her ya want a colder heat range plug. Check ing. timing and set at full throttle . Next go up a grade in gas . Open the load screw to 4 1/2 turns to five turns off the seat.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
