Sounds like fuel is restricted from reaching the carb. Check the screen at sediment bowl, and for a rusted gas tank causing the clog, or plugged vent hole in the gas cap. Set the dist. back to where it was.Yes, Lean mixtures will make it backfire, especially on a cold engine. Also I would file the points a bit and put in new plugs too as long as your at it,might as well, then all your ignition will be up to snuff.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
