Re: A few more questions on my 49 M
Posted by D Slater on July 08, 2012 at 04:37:49 from (184.15.36.245):
In Reply to: Re: A few more questions on my 49 M posted by Patrick HMD on July 07, 2012 at 20:56:00:
That bolster was used from 1954 to 58. When it was installed on a SMTA gas tractor the worm steering shaft was made longer. Fan housing changed. Upper radiator support rod longer. Rear steering shaft support changed. Cast lower coolant hose made different. Top coolant hose longer. Hood longer. Some hand crank parts different.
If satisfied with the hood looks and other things there's no reason to change. Power steering installation has already changed part of the original parts. Hood with piece added to make longer and a longer coolant hose probably handled the rest.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
