Posted by John 37A on July 24, 2012 at 15:47:25 from (69.223.129.233):
I just converted my m to 12v neg ground, added an alternator (3 wire delco), Pertronix electronic ignition with a flame thrower coil, and completely re-wired it. I did so using the schematic on this site, with the exception of no warning light, and no resistor to the coil (was told none was needed with a 3 ohm coil).
http://www.ytmag.com/articles/artint195.htm
When I first started the engine, the tractor ran great, but would not shut off. it will not start with the Ignition switch off, but stays running with the switch in either position, and I have been choking it to kill it.
Any ideas? I"m not an electrical guru by any means.
This post was edited by John 37A at 15:49:22 07/24/12.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
