Nothing magical about it. If you were to double the amps(which you don't) you would need bigger cables yet.Voltage is determined by the # of cells in the battery. Amps are from the size and # of plates. A 12 volt of the same size as a 6 can't double the amps cause there are only half as many plates( more or less ) to a cell. It is the voltage that causes the starter to spin. Loose a couple volts & the starter slows down even if the amps are there.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
