Posted by equeen on July 31, 2012 at 21:25:46 from (209.102.248.236):
If this works, there will be two photos: One of the parts I've removed from the busted block (354898R1)off a Super A. The other is a view of the busted block with sleeves still in block.
From what can be seen in photo, does it appear worth it to salvage the sleeves (3.25)?
Crankshaft pulley, is it simply a press fit? I'm not having any luck getting it to budge with a gear puller. Heat next; or is there a set screw or something holding it that I'm missing?
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
