Re: '39 A rear weights
Posted by Red Dave on August 08, 2012 at 10:45:19 from (66.216.141.163):
In Reply to: '39 A rear weights posted by davset on August 08, 2012 at 09:13:42:
I'm not sure exactly what you are asking about.
If you mean the 140 lb bolt on weights, then they are used in pairs.
If you are refering to the heavy cast wheel that is on the right-hand side of an A, then that weight is only on the right, to balance the tractor.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
