Posted by Bob M on August 14, 2012 at 18:54:21 from (67.240.168.11):
In Reply to: Clutch stuck on SH posted by Va Gasman on August 14, 2012 at 18:02:35:
Clutch disk has gotten stuck (rusted) to the flywheel/pressure plate. It happens sometimes to my SH when it sits idle too long. Breaking it free is simple:
- Move the tractor to hard, level piece of ground
- Start the engine in neutral, let it warm up a few minutes then shut it down. (This is so it will start easily in the next step)
- Put the transmission in 4th and restart the engine. (If it won't start in 4th, start it in 1st then with the engine idling "snap shift" it sequentially thru the gears into 4th.
- Now depress the clutch, open the throttle wide then step HARD on both brakes. The clutch should break free as the engine gets dragged down.
If this doesn't do it, with the tractor rolling in 4th, float shift it into 5th then repeat the last step above.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
