Posted by The tractor vet on August 18, 2012 at 08:16:12 from (76.212.225.255):
In Reply to: 806 stuck posted by Kly on August 18, 2012 at 07:54:57:
If it were me as i do not believe in the snake oil treatment myself i would pull the head off as for the WD 40 haw your waisting your time . Once the head is off then and only then can you CLEAN out the rust with a hone and then get your self a can of ZEP penetrating fluid as it is the best you will ever find and it is not easy to find or cheap but it does work . Once the hole or holes are cleaned out then a block of hard wood and a good BMFH and a couple raps and it will turn then clean some more change oil put head back on reset valves and start and run till warm re torque reset valves run for fifty hours and retorque head again .
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
