Posted by D Slater on August 18, 2012 at 17:39:18 from (184.15.20.202):
In Reply to: Head bolt question posted by BigTone on August 18, 2012 at 14:14:14:
Some of those studs above the coolant cover go through into the coolant. Thats what makes them harder to get out than the others most times. I use thread sealent on those. If you notice the studs are not threaded a full thread length in the block originaly. Sometimes if you get carried away with a thread tap in the block holes and the original studs are used and go in a full thread to tighten. Some studs may end up short on having a full thread for the nut on top.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
