Posted by Jim Paterson on August 25, 2012 at 11:11:44 from (71.238.209.130):
I was reassembling the engine on my '44 H and realized that I didn't have a critical part ready. The problem - I already sprayed the coppercoat gasket sealer on the gasket that goes between the block and the metal plate between the block and the gear cover. I have not tightened anything, so my question is: will I have to get a new gasket or will I be able to torque the cover bolts and still have the gasket seal properly if I wait a day or two?
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
