Re: H front tire question
Posted by SadFarmall on August 26, 2012 at 02:27:28 from (121.79.19.24):
In Reply to: H front tire question posted by Chuck R in TX on August 25, 2012 at 08:47:43:
I wish it only cost $6 here to get a tyre fitted here. More like $20 each on a good day. I do my own, front and rear on our tractors. When I fitted new front tyres on our Farmall H (5.50-16) I had the rims blasted and painted. To avoid damage I lay the rim on some heavy cloth and applied a liberal amount of rubber grease to the bead on the tyre. Easy to force the tyre on without any levers at all. Then fit the semi inflated tube and repeat the process for the other bead. The second bead is a little more trouble and may require two people to get enough push to force it on. If all is well the tube will behave. I have never pinched a tube by this method and it removes the possibility of damaging paint with a tyre lever. The rubber grease stops the bead rusting on to the rim.
SadFarmall
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
