Posted by WD9ER on August 29, 2012 at 07:21:36 from (65.127.84.74):
I was wondering if there is an easy way to tell if my generator is charging on my WD-9? Currently, the headlight and rear light are not working (possible grounding issue) so I am not able to put a load on the electrical system. The batteries measure 12.25 volts across both battery prior to starting and approximately 12.0 volts after it has been started. The ammeter shows a hair above zero. Any advice would be appreciated.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
