Posted by kopeck on August 31, 2012 at 19:14:02 from (66.243.207.180):
I have a 52499D off my '47 A that I've been trying to rebuild but haven't had a whole lot of luck.
The deal is the idle adjust screw/jet doesn't have any effect of the engine. I can have it seated or 4 turns out no change.
It has been soaked in carb cleaner and a kit installed. I use compressed air to blow everything out. I also used spray cleaner as well.
I've been told it might be something stuck int he idle circuit, if that's the case what can I do do remedy the situation?
The other thing was thinking about is getting new throttle shaft bushings installed. I couldn't find that it was leaking (propane test) but there is some play.
Any pointers would be welcomed. I've rebuilt a handful of carbs but this one is driving me nuts!
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
