Re: Adjusting pto shaft length on #5 JD sickle bar
Posted by Va Gasman on September 14, 2012 at 19:53:53 from (75.192.87.255):
In Reply to: Adjusting pto shaft length on #5 JD sickle bar posted by Pat B im Mich on September 14, 2012 at 17:36:51:
I have a No.5 I run on SH. The shaft telesopes fairly easy. Check to see if it's stuck. There is also a type of clutch built in to it.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
