Re: Axle seal leaking a bit on 300.
Posted by Bob3 Martin on September 28, 2012 at 07:53:31 from (71.7.75.192):
In Reply to: Axle seal leaking a bit on 300. posted by Iowawill on September 28, 2012 at 07:45:55:
Probably replacing the seal isn't difficult once you have the tire/wheel off it. The problem is whether the bearing needs replaced.
If that's the case, I believe you have to go inside the bull gear to pull the axle to replace the bearing.
I'd raise the sucker up off the ground and see it the bearing has a lot of play in it. Then decide how far you want to go.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
