Re: steering shaft end play
Posted by Janicholson on September 29, 2012 at 19:57:30 from (96.24.99.126):
In Reply to: Re: steering shaft end play posted by beatle on September 29, 2012 at 18:32:57:
Assuming the bearing in the worm is good, and tight in the housing: Three issues, the sector gear to worm can wear allowing real gear lash. It is not adjustable on this tractor, and is repaired with new, or good used gear/s. The second is possible wear or hogging out of the sector to shaft key, the third is the attachment of the steering arm to the shaft. if it is loose or wallowed out the same steering play can happen. Jim
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
