Rub the points with some 320 wet or dry until shiny then see if the engine will start. If you still have a no start and you have a distributor use a volt meter and check for battery voltage on both small terminals with the points open and your ignition switch in the on position. If there's no voltage you need to trace that wire back to your ignition switch and check for voltage at the switch. No voltage at the switch you need to see if there's being fed to the switch. If voltage is fed to your switch your switch is probably defective. Clean the terminals on the switch to make sure there's good contact. Hal
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
