Ing. timing not set correctly , wrong heat range spark plugs, fuel screw not set correctly . idling to high , to low octane fuel . centrifugal advance not working properly (leads back to ing. timing) , running way to hot ( that goes back to lean fuel mixture , timing , wrong heat range of spark plugs , sticking thermostat, poor coolant flow dirty rad.)
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
