Re: How do i charge my batteries?
Posted by mkirsch on November 01, 2012 at 06:51:08 from (64.80.110.74):
In Reply to: How do i charge my batteries? posted by kennell on October 31, 2012 at 16:05:37:
Before you ASSUME the left battery has the main positive terminal, take a look.
After 40 years it is possible that someone rewired the tractor and changed it.
If the cable goes from the + post directly to the starter solenoid, then you have the main positive terminal on the left battery.
The cable MUST go from the + terminal directly to the starter solenoid.
A second check, the other cable should go from the - terminal across to the + terminal on the other battery.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
