Re: antifreeze or water
Posted by willie in mn on November 04, 2012 at 19:05:14 from (67.142.168.21):
In Reply to: Re: antifreeze or water posted by randy hall on November 04, 2012 at 12:30:22:
Good theory, but you got it hind end around bassackwards.
Back in 50s, early 60s people in warm climates such as so Tx, Fl, Az, Ca ran just a quart of antifreeze to lube water pump & in case they got a little frost.
Then with A/C becoming a popular option, they had overheating problem due to the increased cooling load. Remedy was to run 50/50 mix in everything year around.
Willie
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
