Double nosed Char-lynn torque generator
Posted by mkirsch on November 12, 2012 at 05:50:50 from (64.80.110.74):
Originally, I thought the Char-lynn torque generator was mounted backwards on this tractor:
third party image
It's mounted facing the correct way. The difference is, it has TWO NOSES.
Normal char-lynn units have a smaller diameter nose on the output end of the motor, like this:
third party image
Mine has the same tapered section on BOTH ends of the unit. I've never seen one like it.
What tractors would have had the aftermarket power steering up at the steering wheel like this?
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
