Re: 1206 PTO linkage adjustment
Posted by The tractor vet on November 30, 2012 at 15:53:15 from (76.212.227.196):
In Reply to: 1206 PTO linkage adjustment posted by oldtanker on November 30, 2012 at 12:51:28:
IF the valve stem is going ALL THE WAY DOWN then IT should stop as the PTo brake is SPRING loaded and when you ingauge the PTo Hyd pressure that loc.'s the clutches up release the brake . But to be sure that the valve is shutting off you would have to have the Special fitting to go into the test port and a gauge like said below of 0-600 psi . And with the lever in the off position a reading of 0 will be on the gauge and asyou pull the lever up you shoud get somewhere near 30-40 psi and then anyplace between 210 - 250 . BUT YA GOT TO HAVE THE special fitting and a gauge . Now the other thing that will keep the PTO turning is wrapped clutches, and that will call for a rebuild.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
