Posted by mschwartz on December 02, 2012 at 12:31:18 from (216.163.99.163):
Have some questions on the routing for the original distalite fuel system? Tractor is pretty original looking, has a 90 degree shutoff under main tank. This is routed over to bottom of starting tank where there is a normal IH sediment bowl. Outlet is plumbed directly behind the head and down to carb. Is this setup correct? After setting for 30 plus years in barn it started up on the old gas that was still in the tank, must be progress as new gas will barely run a tractor after 3 months. Tractor has working shutters and the manifold heat sheild so I am hoping all of these parts are correct as it would be kind of cool to keep it all original. Thanks, Mike
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
