Re: Mis-aligned cam bearings
Posted by Nebraska Kirk on December 25, 2012 at 16:59:54 from (207.91.4.159):
In Reply to: Mis-aligned cam bearings posted by Fritz Maurer on December 25, 2012 at 08:38:36:
I have disassembled a couple of F12 engines and have had the same thing happen to me. What happens is that many years of use wear the gear to the point that a little burr is raised along the edge of the teeth, this makes the gear just enough bigger to scrape the bearing when you remove the camshaft. Grind or file off that burr and it will go back in without scraping the bearing.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
