The amount of pressure is best delt with by thin gaskets. Uneven mating surfaces and low pressure are best delt with by thicker gaskets. Material and compression of the fasteners that hold it together depend on a certain amount of compliance to assure good seal. Material choice is also based on what is being sealed some materials are dissolved by the flow through the passages being sealed up. Some gaskets are also thickness shims and are designed to be used in a stack or selected to make bearings preload, or gears mesh correctly. I hope this helps, Jim
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
