M head stud update
Posted by ss409 on January 08, 2013 at 07:32:34 from (72.53.194.237):
thank you all who contributed information on how to remove stuck head studs. I heated the stud with a butane torch, then tapped the stud with a hammer then let em cool, I did use the wax method! fellas, they came right out with a small pipe wrench! i did one at a time, heated the stud only just till i seen a lil smoke,, then hit it with the candle wax then let it cool. worked like a charm! thank you.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
