Re: Delco-Remy Generator Output
Posted by SadFarmall on January 20, 2013 at 17:43:56 from (112.213.196.137):
In Reply to: Delco-Remy Generator Output posted by SadFarmall on January 18, 2013 at 04:23:41:
Thanks for the good advice. I'll check the system over thoroughly. The generator is Delco and a newly reconditioned unit. The VR is also new. The belt is new. The wiring is all new and everything has been carefully grounded where required. I fitted ground wires back from each light and from the VR, so that everything runs directly back to the positive cable.
The tractor starts easily every time and the battery doesn't seem to have gone flat yet. I get 10amps showing on the ammeter with the lights off.
The C39 generator I referred to is fitted to my Farmall M, which runs a complete Lucas system. It works well, but it is a real nightmare to set up the regulator connections.
Thanks again.
SadFarmall
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
