Posted by D Slater on February 01, 2013 at 17:30:09 from (184.15.3.229):
In Reply to: w6 transmission in a m posted by zanslastclu on February 01, 2013 at 17:05:46:
Yes, but if I remember correct not all W-6 had standard gears the same, serial number break. Think the ones with the faster standard ratio used one tooth more than a M driving a one tooth smaller than a M gear for 4th. Still a little slower than a SM 4th. Have some notes with gear counts from switching gears. Don't have time to look now, maybe a little later.
Okay first gear was the one with a serial # break. Going to list some gear teeth with the first # driving the 2nd number. 3rd gear M, 26-34. W6 27-36. 4th gear M, 29-34. W6 30-33. Second is the same in both, Most of the W6 used slower first gear ratio than a M. Posted standard gears, both had the slow first and high speed 4th option. SM 4th used a 33 tooth driving a 30.
This post was edited by D Slater at 18:41:45 02/01/13.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
