Re: Farmall Super A hydraulic block safety valve stuck
Posted by WellWorn on March 25, 2013 at 19:23:25 from (67.246.141.21):
In Reply to: Farmall Super A hydraulic block safety valve stuck posted by Scott A Johnson on March 25, 2013 at 09:30:20:
Hi Scott.
I don't have access to my parts book (visiting 'downtown' for some high speed internet, vs the snail dialup out at the farm), but at one time I found a touch control service manual reproduction posted on the web, possibly from a link on YT - though I can't seem to locate it at present.
The TC-39 parts book has a pretty good parts breakdown diagram, which if you are doing much if any work on your SA, would be well worth the investment.
I did rebuild the touch control block on my SA, but I don't recall not being able to access the relief valve parts. If I recall it correctly (and I admit I could be wrong), the ball and spring install from the head side, with pump pressure internally ported to the ball side of the assembly. All you should have to do is make sure the port is not obstructed (blow it out with air), the valve (ball) seat is clean and shiny, and the ball has no pits. If in doubt of the spring's condition, replace it.
Hope this is of some help.
Well Worn
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
