Re: Replacing Transmission Seal on Farmall B
Posted by gene bender on April 04, 2013 at 19:20:57 from (67.55.226.151):
In Reply to: Replacing Transmission Seal on Farmall B posted by jkmdg84 on April 04, 2013 at 08:51:25:
to replace the final seal you will need to remove the brake drum then the cap on the final so the diff shaft can come out thru that opening then you will find the seal in the final
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
