Posted by peanuthil12 on April 17, 2013 at 08:47:04 from (99.196.154.202):
Hi all.
Don't want to just sign-up to this deal and start asking stuff so Here's a little about me
I am retired Army up in Dalbo (near Cambridge) Mn. built on 10 acres in '03. retired in 06, bought a farmall 300, side rake, bailer, syckle cutter, and am doing my own hay.
I've split this tractor 2wice and learned a lot. Now I'm running into charging issues.
I follow the (converted 12V) alt., single wire, to the dash where it goes to a on off toggle. then to a voltage regulator on the left side. At least that what a picture of the replacement item shows on Yesterdays tractor replacement part list. I'm pretty sure I fried something somewhere as I saw smoke coming from the dash at one point after I tried replacing the toggle.
All finished with replacing the switch. started cleaning out the cow pen and the gage showed the batt charging. Didn't have a problem the rest of the day. Went out this morning and ran her a bit, shut it down after noticing that the gage didn't look like it did yesterday. Not charging I figured. Went to start it back up. no deal, battery drained.
Should I replace the voltage regulator, the alternator, or wiring, or all of the above?
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
