changing super c to 12 volt.
Posted by truckerlary on April 17, 2013 at 16:58:57 from (12.19.152.194):
I have a super c that was 6 volt and was charging on 6 volt. Decided that I wanted to change over to 12 volt still using the 6 volt generator. Bought a new 12 volt regulator and installed the new regulator same as 6 volt that was removed. Left the tractor wired positive ground, installed porcelain block to reduce voltage to coil, installed 12 volt battery. Polarized the new regulator. Now when I start the tractor amp gauge goes all the way to the discharge side and stays there for a while even after shutting tractor off. Eventually it comes back to center. Can bring it to the center with a magnet also.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
