Re: Super C governor spring
Posted by teddy52food on April 28, 2013 at 08:09:22 from (184.94.175.179):
In Reply to: Super C governor spring posted by Rick Remmert on April 27, 2013 at 17:58:13:
Check that part that the spring is hooked to & make sure it is tight to the shaft. There is a pin holding it on which may be sheared off part way.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
