Posted by mkirsch on May 06, 2013 at 04:39:47 from (216.43.0.134):
In Reply to: Chydraulics posted by 292 Ralph on May 05, 2013 at 17:11:20:
Even if you use the test port you will still need a separate spool valve to control the haybine. There is no way around it.
The hydraulic capacity of the C is very small, and should always be completely full.
When you hook on to a raised haybine and try to lower it, the hydraulic oil will have nowhere to go.
When you hook on to a lowered haybine and try to raise it, the tractor can run out of hydraulic oil and ruin the hydraulic pump.
You absolutely need an external tank for additional hydraulic capacity. Minimum 3 gallons capacity, vented, about half full so it has somewhere to catch excess oil from raised implements.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
