First of all it can be done at home. First rule of anything to do with pumps is it's got to be clean. There are two o-rings on each of those (throttle and stop) shafts, you'll also need a gasket to replace the one under the pump cover. If I remember correctly there is a spring that has to be disconnect as you lift the cover off, hopefully someone else can chime in with a picture. Good luck, Sam
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
