Posted by gbs on May 14, 2013 at 18:54:23 from (64.234.38.41):
In Reply to: Hopper Gear posted by asyrp43 on May 14, 2013 at 12:34:57:
try a couple of adjustments before replacing it,first if you will notice in the photo the machine shims between the drive gear and shaft bearing add some more to correct excess end play,next adjust the rod that hooks to the lift arm to give only enough clearance between the gears that they just miss each other when the lift is fully up,also check the spring on the drive gear for freedom of movement and or damage,i had one several years ago that would skip like yours as a last resort i done a poor mans fix by grounding the drive edges of each gear to a little flatter angle worked good for several years
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
