Well said. They go round and round on this subject on the Ford N board too so I made up a list of reasons to go 12V. *12V spins your engine faster and starts it better in all conditions, especially if it is very cold or if the engine has marginal compression. *12V with an alternator is more reliable and uses a solid state VR instead of an old fashioned system of points, coils and electromagnets to regulate the charging voltage. Solid state is better, more accurate, more dependable. *12V is more forgiving of dirty contacts on/in the entire wiring harness. *12v is the industry standard and has been for 50 years. *12v allows you to run sprayer pumps, flashing lights, winches and a host of other modern accessories on your tractor. *12V lights are brighter. *A 12v alternator will easily put out more amps than an old fashioned generator and vr. *An alternator will charge at an idle. Generator generally will not. *A 12v system is safer. For example, Most people know how to jump a 12v negative ground car, truck or tractor. Not many people know how to safely jump a 6v positive ground tractor with a 12V battery without something exploding in their faces or getting themselves run over. *6v requires bigger, harder to find wires and cables throughout the system. *12v batteries are to be found just about anywhere, are cheaper than 6v and are usually maintenance free. * And last but not least, is this your only 6V machine? What kind of battery is in your boat, motorcycle, lawn tractor, RV, your classic car or even your 4 wheeler or snowmobile if you have them? Why have an odd ball battery that can't jump or be jumped by anything else?
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
