Posted by wayne in mn on May 18, 2013 at 19:20:19 from (71.8.147.153):
In Reply to: Compression on 300 posted by DKRod on May 18, 2013 at 19:04:45:
Check the valves for proper clearance. Next: get a compression tester and, 1.test for compression with throttle set wide open, 2.squirt about a teaspoon of motor oil into each spark plug opening, 3.spin the engine a few times, and then 4.re-test the compression. If the test results increase markedly with the addition of oil, the engine likely needs an overhaul.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
