I played hell getting my 560 running and found out the check valve in the return line decided to quit working. it would run for a bit then act like it was starving then die. let it sit for about 20 minutes while the pump filled back up and would run for a bit. if you cranked right after it died, it wouldn't smoke one single bit even with the throttle wide open. might be something to check
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
