Posted by VA Gasman on June 20, 2013 at 19:41:34 from (75.197.113.74):
In Reply to: Engine Stuck posted by Mark58 on June 20, 2013 at 10:15:07:
I had a SH with 2 pistons stuck. I soaked for 2-3 weeks. Then I built fire in the cylinders and let it burn out; this I believe helped some because I saw corrosion release. Then I chained a 4" x 1/4 piece of square tubing under the tractor and hanging from the side rails. The I placed a 8 ton jack under the rod that had been disconnected from crank and set it on tubing. I cut a piece of 5/4" oak to the radius of the rod and pushed the piston and sleeve out of engine. this was ok because I went back with new sleeves and pistons from this site. Took several attempts because the oak block would kick out but it worked. All rods went back and I am using the tractor every week now.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
