Re: 10-20 flywheel removal.
Posted by Nebraska Kirk on July 09, 2013 at 16:23:09 from (207.91.4.159):
In Reply to: 10-20 flywheel removal. posted by loren in wi on July 09, 2013 at 14:20:05:
As special heavy duty puller is needed to remove the flywheel. It can be done without removing the engine, provided the puller is short enough to fit.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
