Posted by davidrz on July 25, 2013 at 10:54:13 from (216.183.60.107):
Posted July 18th regarding a problem with a 1975 IH Cub. Could not get spark all the way to the plugs. Had new ignition switch, new coil, new points, condenser, rotor and some new wires.
You all responded with great detail of what I needed to look for. Did most of what you all told me and I was able to trace the problem. The piece of "metal" or "tin" of the points that goes on the connection inside the distributor which goes to the coil, was making "ground". It was hard to see, but once I took off the distributor again and moved things around, it worked.
Thanks for your quick, helpful, informative response. David
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
