Re: 656 TA/clutch housing install issues
Posted by pete 23 on July 29, 2013 at 11:19:23 from (74.47.41.165):
In Reply to: 656 TA/clutch housing install issues posted by Kevin NE Ohio on July 28, 2013 at 17:50:39:
Well, I am sure I could look at pressure plate and tell but I have seen a ton of plates over near 60 years. The fingers on a good clutch normally lay parallel to the face of the pressure plate. As linings wear the fingers move back toward throwout bearing. If your fingers are less than parallel toward the flywheel, I would suspect collapsed backing plate on clutch. Far as pilot bearing causing shift problems I can't say just what is or isn't taking place in there. That is why I suggest jacking up rear tire and manually moving all linkages forward and back into all gears to try to determine if there is a problem internally or externally.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
