Posted by Tom Fleming on July 31, 2013 at 17:03:35 from (67.20.233.75):
In Reply to: red coat sealer posted by rterry on July 31, 2013 at 03:35:16:
Guys, I think I have posted this before, but I use Caswell epoxy tank sealer. Once again, it is NOT cheap, but it is one of the absolute best ones on the market. It is a true epoxy, and after appropriate curing (depends upon temp), it is 100% impervious to any of the common fuels out there today, including pure ethanol, diesel, gasoline, kerosene, and high octane racing fuel. There is no better if you truly want to seal the inside of your fuel tank.
Once applied, you you won't dissolve it, nor will it flake off, soften, crack, or fail. I don't own stock in the company, but when I coat a tank, it is the only thing I use. Eastwood sells it. Ebay has it. Amazon has it. Caswell also sells direct.
So, if you want to do it once and never again, use it.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
